Hello,
I was having an issue when placing electrical receptacles. Basically, the automatic "elevation" constraint takes over and overrides the height my family was built at above the reference level. I have tried adding an instance parameter to adjust the families after placing with no luck - making adjustments to this parameter after placing the object has no effect. I thought maybe Revit just overrides the heights of these objects no matter what, but then I found a family that I had built for another project that works somehow! You can adjust the "placement" parameter after inserting the receptacle and it works perfectly (and somehow the "elevation" constraint stays the same).
I've tried recreating it to figure out why it works, but even with every setting (that I can think of) being the same, I can not manage to recreate it.
I know A LOT of other users have had similar issues, so I was hoping to investigate the 'working' family and report back on how it works... but I need help.
I've attached this family for you all to dissect.
If you aren't sure why I would want a family based parameter, instead of the built-in Revit "elevation" constraint, here's why: My goal is to have a checkbox for an over counter receptacle in the family. When you check this the height is adjusted to a specific preset. Can't seem to do this is the parameter is being ignored.
Thanks in advance for the help!
