Thread: Creating a new layout and setting it current
    2003-06
    13
    Default Creating a new layout and setting it current
    I have a section of code that creates a new layout and sets if current. It works in 2014 AutoCAD but I cannot get it to work in 2016 AutoCAD. I combed through this several times and cannot figure out why it keeps erring out. It catches the error at the line "LayoutManager.Current.CurrentLayout = acLayout2.LayoutName"
    Any help would be greatly appreciated.
        Public Sub CreateLayout(ByVal db As Database, ByVal ed As Editor, ByVal doc As Document, ByVal LayName As String, ByVal myPSxrefs As ArrayList)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Using layouts As DBDictionary = DirectCast(tr.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite), DBDictionary)
                        ' Add a number at the end of layout name if already exists
                        Dim i As Integer = 0
                        Dim OriginalName As String = LayName
                        Dim x As Double = 25.4 * CDbl(TB_X.Text)
                        Dim y As Double = 25.4 * CDbl(TB_Y.Text)
                        Dim myPlotOrigin As Point2d = New Point2d(y, x)
                        ' Create and activate the new layout
                        Using myLockDoc As DocumentLock = doc.LockDocument()
                            Dim acLayoutMgr As LayoutManager = LayoutManager.Current
                            Dim layoutId As ObjectId = acLayoutMgr.CreateLayout(LayName)
                            Dim acLayout2 As Layout = tr.GetObject(layoutId,
                                                       OpenMode.ForRead)
                            If acLayout2.TabSelected = False Then
                            End If
                            'Plot Settings
                            '' Get the PlotInfo from the layout
                            Using acLayout As Layout = DirectCast(tr.GetObject(layoutId, OpenMode.ForWrite), Layout)
                                Dim acPlInfo As PlotInfo = New PlotInfo()
                                acPlInfo.Layout = acLayout.ObjectId
                                '' Get a copy of the PlotSettings from the layout
                                Dim acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType)
                                acPlSet.CopyFrom(acLayout)
                                '' Update some properties of the PlotSettings object
                                Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
                                Dim myCTB As String = "LBI-Full.ctb"
                                Dim device As String = "Bluebeam PDF"
                                acPlSetVdr.SetCurrentStyleSheet(acPlSet, myCTB)
                                acPlSetVdr.SetPlotConfigurationName(acPlSet, device, myMediaCanonical)
                                If CB_SheetRotation.Text = "LANDSCAPE" Then
                                    acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees090)
                                End If
                                If CB_SheetRotation.Text = "PORTRAIT" Then
                                    acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000)
                                End If
                                If CB_SheetRotation.Text = "LANDSCAPE(Upside Down)" Then
                                    acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees180)
                                End If
                                If CB_SheetRotation.Text = "PORTRAIT(Upside Down)" Then
                                    acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees270)
                                End If
                                acPlSetVdr.SetPlotType(acPlSet, DatabaseServices.PlotType.Layout)
                                acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
                                acPlSetVdr.SetPlotOrigin(acPlSet, myPlotOrigin)
                                acPlSetVdr.SetUseStandardScale(acPlSet, True)
                                If myPSxrefs.Count > 0 Then
                                    attachXrefsTypes(myPSxrefs, "TTBL")
                                End If
                                ed.Regen()
                                '' Update the layout
                                acLayout.CopyFrom(acPlSet)
                            End Using
                        End Using
                        tr.Commit()
                    End Using
                Catch ex As System.Exception
                    Dim Msg As String = "Error in function Create Layout"
                    Dim Title As String = "Operation cancelled"
                    MessageBox.Show(Msg, Title, MessageBoxButtons.OK, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button1)
                    MsgBox(ex.Message & Err.Number)
                    tr.Abort()
                End Try
            End Using
        End Sub
    Last edited by BlackBox; 2016-03-07 at 03:01 PM. Reason: Fixed a [CODE] tag, and moved to .NET forum
    2009-11
    5,719
    Default Re: Creating a new layout and setting it current
    What does the Exception say?
    Try:
    '' <snip>
          acLayoutMgr.CurrentLayout = acLayout2.LayoutName
    '' <snip>
    Also, for reference:
    Creating an AutoCAD layout with custom plot and viewport settings using .NET
    Cheers
    Computer Specs:
    2003-06
    13
    Thanks, but it didn't work. I guess I forgot to mention the error I am getting which is error #5, esetfailed. Best I can tell by searching what this error is, is that I am trying to set a layout current that doesn't exist.
    2003-06
    13
    Playing around with the order of the code and it seems if I create the layer and set it current before the "USING" call, it works again.
    2009-11
    5,719
    Glad you got it sorted.
    Cheers
    Computer Specs:
  1. Blocks in current layout
    By timlane in forum VBA/COM Interop
    Last Post: 2009-03-26, 07:37 PM
  2. Setting a drawing current.
    By kdayman in forum VBA/COM Interop
    Last Post: 2008-08-28, 09:18 PM
  3. REFEDIT to follow current SaveAs Setting
    Last Post: 2005-12-05, 02:55 PM
  4. Setting the Current Plot Configuration Programatically
    By Marshal_Rosenberg60828 in forum VBA/COM Interop
    Last Post: 2004-06-18, 03:56 AM
Tags for this Thread
