Hello all,
I'm having a strange issue with a window family's opening cut. Opening cuts are unlike a void extrusion where you can't modify how deep it cuts. For instance, I wish it was possible to add a small buffer or offset from the interior/exterior face of the wall on the opening cut. Unfortunately, void extrusions do not seem to cut through the hosted wall (other extrusions and created elements only). Specifically a curved wall joining with another wall is where I'm having issues with the family cutting. The window elements were created in the window-hosted family and not nested in. Below are two pictures in plan view. The first shows the wall join condition (where I've hidden my window family) and the second shows the window family with the strange piece not being cut on the joined and non-hosted wall. I'm thinking this problem is happening since this wall isn't the window's true host, but happens to overlap the join condition. Also, it could be because my family is designed for a linear wall and not to adapt to a curved one (I don't want any of the window's components to be curved). Any thoughts? I'd prefer not to recreate the family if possible.
Thank you for your time,
AJM
