able to hide a dimension within a string
Summary: created a string of dimensions and don't need a dimension in the middle of the string.
Description: As a string of dimensions are created along the floor plan dimensioning every wall face, without breaking the dimension string, remove the wall width dimension.
Refer to ACA AEC Dimension Style dimension strings where you can hide just the text and/or hide text and dimension line within that string without breaking it.
Product and Feature: Revit Architecture - Annotation Tools
Submitted By: htlmv on 03/24/2016
Re: able to hide a dimension within a string
Why not follow the National CAD Standard and dimension to one face of the wall?
You can TAB select the dimensions in between and delete them. If you don't want to see them then you can argue you don't need them either. If you want to be able to move the string up/down just select them together first. Hiding things is getting out of hand.
I understand and share your request.
Meanwhile, you can override the dimension text and replace it for a point. It would be better to replace it for a blank space but doesn't work
- You may not post replies
- You may not edit your posts
Forum Rules
