Thread: AutoCAD 2017 "Publish" Command Missing
    Member Meical ap Gwaredd's Avatar
    2005-07
    Mars
    20
    Default AutoCAD 2017 "Publish" Command Missing
    (Sorry about the prefix, there is no 2017 on the pull down)
    We just updated our AutoCAD to 2017 and it seems that the "Publish" Command is gone.
    Funny thing is, it's still on the pull down menu under "File" and if you go to "Output" on the ribbon and hit the "Batch Plot" icon, it's gone from there as well.
    The Icons are there, it's the command that's missing.
    In all 3 cases, we are getting a "Unknown command" message.
    Anybody know what's going on?
    Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    Default Re: AutoCAD 2017 "Publish" Command Missing
    I don't see why that command would be removed. Have you tried running the command from the command line? if not, have you tried a reinstall or repair?
    2015-12
    2,095
    Before a repair or re-install, check to see if the demand-loading flag is set. This is probably a load-on-command-call function, so if the flag is cleared it will always report as an unknown command.
  1. 2017: Autocad 2017 Dimension editing issues
    By IanR in forum AutoCAD General
    Last Post: 2016-04-06, 01:23 AM
  2. 2007: Publish Command says unknown command in autocad 2007
    By drajappa594109 in forum AutoCAD General
    Last Post: 2012-07-13, 03:34 PM
  3. Replies: 9
    Last Post: 2007-04-05, 02:36 PM
  4. Publish command crashes AutoCAD 2007
    By BushDog1 in forum AutoCAD General
    Last Post: 2007-03-12, 03:27 AM
  5. Replies: 2
    Last Post: 2006-07-18, 10:43 PM
