Hello,
We have noticed (on Revit 2015), on several different projects, that there is some error in which a downstream panel's loads per phase are showing up reduced on upstream panel schedules.
I know a couple known bugs, and we have checked that none of the loads are spares with dummy loads, and all power factors are set to 1. See attached pictures. EL1AC/HS is the upstream panel feeding EL2AC/HS. You will notice that the third phase is the same on both schedules, but the other two phases are not.
Does anyone know what's going on here?
