Thread: Vault Basic - Add R/W Library to Current Vault Project
    2014-02
    9
    Default Vault Basic - Add R/W Library to Current Vault Project
    Hi All!
    The vault projects properties in the project editor are not editable. Is there a way to add a r/w library to the vault project I'm currently using?
    Background:
    I have been using inventor with vault basic since 2015 release. I have a single vault project I use for everything. I have upgraded to 2016. I have been working on a project that requires a MT/WT T from the Frame Generator and this part worked when I started this project in the 2015 release. Now in 2016 there is a known bug for this frame generator part. The work around would be to publish the T part I need to the content center. Works fine in a non vaulted project but because I don't have a r/w library in vault it fails.
    The first fix would to have Autodesk release a fix for this frame generator part but till then.... I'm Stuck.
    I'm a noob when comes to vault and vault has been a mix of pluses and minuses since I started using it, but we are a multi user environment so I feel we need to use it.
    The vault projects properties in the project editor are not editable. So I can't add a Library directly. Is there a way to add a r/w library to the vault project I'm currently using? Or is there a different solution?
    FIY: In my Vault Server Console I have R/W Libraries but I don't see them in the Vault Basic Client or when I create a new vault project in the project editor.
    Thanks for your help.
    John
    293
    Default Re: Vault Basic - Add R/W Library to Current Vault Project
    I have had significant issues with vault, as well, that I just end up living with... That being said, maybe you should take a look at Vault Pro. I have not experienced any issues with any Content Center shapes in FG, including a number of custom profiles, when using Vault Pro.
  1. 2015: Vault basic plot manager
    By markkinkade in forum Vault - General
    Last Post: 2015-04-20, 06:45 PM
  2. 2014: Win8.1 with Vault Basic 2014
    By BeKirra in forum Vault - General
    Last Post: 2013-12-18, 03:29 AM
  3. Connecting Vault basic 2013 client to vault 2012 server
    By eradityabjoshi in forum Vault - General
    Last Post: 2012-05-30, 08:05 AM
  4. Replies: 8
    Last Post: 2007-05-14, 06:44 PM
  5. Replies: 0
    Last Post: 2006-09-18, 03:55 PM
