I attach an example project file which has a wall shown grey, to which a lining shown yellow (another wall type) has been joined to the first wall.
I am trying to create a door family which cuts through both wall and lining with a door frame which runs through both wall and lining, which I also attach.
Please take a look at the North Elevation and South Elevation of the project in Coarse Mode to best see this phenomena, in which the architraves are not visible.
I am perplexed that in the project north elevation the door leaf is not visible (there is an undercut to the door that should show), whereas in the project south elevation the door is visible and the undercut can be seen.
Further, in the project south elevation there is a second line around the door frame (which I assume is the opening in the wall) which does not show in project north elevation.
Can anyone understand why there is a difference in visibilty between north and south views, whilst (I think) the setings for the two views are identical?
Any suggestions what may be causing the door leaf to disappear in north elevation and the extra lines appear around the door frame in south elevation?
Any help or suggestion would be appreciated.
Robin.
