I want to make an element in a family (in this case a sweep), visible in elevation 'Front/Back' at all Levels of Detail, Coarse, Medium and Fine when loaded into a project.
I also want it visible in plan at Fine, but invisible at Coarse and Medium.
Using visibility settings it seems impossible to set this combination on a single setting.
I used to think that Revit stored settings for LOD dependent upon the combination of check boxes selected for plan, Front/Back etc., and store different visibility settings for different combinations, but it seems that only the last LOD settings are stored irrespective of the combination of selected check boxes. Is this an issue of which order the LOD settings are made for each view, or is it just not possible? Or am I missing something obvious here?
It seems to be entirely reasonable to want to display an element at a certain LOD in some views but not others, but I can't see how. Is it really just one visibility setting per element?
Can anyone clarify how this does actually work, and how I can acheive my objective?
Thanks
Robin
