I need a custom hatch that is 36" wide x 6" high with the vertical line off set at 1/3 which would be 12". I'm still a little confused as how to do this with a custom pattern file. I will post the pattern that i am after. I understand that first you give an angle then give an offset but i'm still a little bit confused. Here is my code
*6x36, 6x36 One Third Elevation
0, 0,0, 0,6, 0,36
90, 0,0, 6,24, 0,6,-36
