Thread: Circuit Home run Tag
    100 Club Binu Mathew's Avatar
    2005-11
    Kuwait
    187
    Default Circuit Home run Tag
    Hi all,
    Does anyone knows why in circuit home run tag (eg: DB.GF.01/R1) always displaced. after we Tag the Homerun we used to place the Tag by not overlapping the Arrowhead or any object unfortunately after we synch. or the next day we open the file the homerun tag again will go back to the original location which will overlap other object this makes us worries any help.
    Thanks for your time
    2014-05
    13
    Default Re: Circuit Home run Tag
    We are having the same issue. We are worksharing, and the local file of the user whom created the tags is fine and looks correct, but when another user opens the same view the tags are in the wrong spot. When the user with the wrong tag locations clicked on the tag, the tag moves with some strange random offset and then will move normally after its been moved once. Please advise. this has happened to our projects on multiple occasions. Thank you.
  1. Motor Circuit Schedule / Panel and Circuit Number
    By cyriousn in forum Revit MEP - General
    Last Post: 2015-02-08, 01:47 AM
  2. Branch Circuit vs Feeder Circuit for Voltage Drop
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-12-01, 02:31 PM
  3. Replies: 3
    Last Post: 2014-11-17, 05:09 PM
  4. AMEP 2009 Circuit Manager (Circuit Descriptions)
    By Eddy B in forum AMEP General
    Last Post: 2008-11-03, 09:53 PM
  5. Multi Circuit Home Runs
    By msmith.161043 in forum Revit MEP - General
    Last Post: 2008-03-11, 04:56 AM
