Results 1 to 9 of 9
Thread: Any wanna take a look on this?
    2015-04
    4
    Default Any wanna take a look on this?
    HI all
    I´m working this Lisp and to be honest I´m new to all this..
    LISP:
    (Defun c:SGM (/ s ss sn i)
     (foreach lay (layoutlist)
        (setvar 'ctab lay)
      (if (setq s  (ssadd)
            ss (ssget "_x" '((0 . "ARC,LINE,LWPOLYLINE") (8 . "GRUPPEOMRÅDE")))
        (progn
          (repeat (setq i (sslength ss))
        (setq sn (ssname ss (setq i (1- i))))
        (if (not (eq (cdr (assoc 100 (reverse (entget sn))))
                 "AcDb3dPolyline"
          (ssadd sn s)
          (if (> (sslength s) 0)
        (command "_.pedit" "_m" s "" "w" 1.4 "")
          (princ "\n .... ")
           ); end foreach
        (princ "\n Couldn't find any 2D polyline !!")
      (princ)
    What it should do is: For each layout go to layer "Gruppeområde" select all lines, arcs ,polylines, 3d polylines and set width to 1.4.
    Any that can see what i do wrong?
    I get the error :"invalid window specification"
    Last edited by rkmcswain; 2016-04-28 at 06:28 PM. Reason: Changed [QUOTE] to [CODE] tags
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Any wanna take a look on this?
    You are not accounting for the value of the PEDITACCEPT system variable. If it is set at 0 and you select items which are not polylines, the prompt to convert them is presented.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    You can only set width to polylines, not lines or arcs. Are you doing that to Paper Space objects or Model Space objects in a viewport? You can change the lineweight of all lines, arcs, and polylines in a viewport using viewport overrides. If you modify the lineweight or width of an object then it would have that lineweight or width in every viewport.
    2015-04
    4
    i forgot to tell that i have this lisp without the "foreach" and it works perfekt..
    it ask if i wanna make the lines and arcs to poly lines.. i say yes and it do the rest by makeing all with 1.4 in line width.
    all the lines in layer"GRUPPEOMRÅDE" is placed in paperspace.
    Why i wanna have this lisp is because we need to see the lines like the printouts when we are placeing symbols in paperspace.
    Earth
    9,805
    Try this, per Opie's solution.
      (setvar "peditaccept" 1)
        (setvar 'ctab lay)
        (if	(setq s	 (ssadd)
    	      ss (ssget	"_x"
          (progn
    		       "AcDb3dPolyline"
    	    (ssadd sn s)
    	(princ "\n .... ")
        )					; end foreach
      (princ)
    R.K. McSwain | CAD Panacea |
    2015-04
    4
        (setvar 'ctab lay)
        (if	(setq s	 (ssadd)
    	      ss (ssget	"_x"
          (progn
    		       "AcDb3dPolyline"
    	    (ssadd sn s)
    	(princ "\n .... ")
        )					; end foreach
      (princ)
    Dosn´t work.
    Stop at 2nd. layout and say invalid window specification.
    This works find but as you see it dosn´t have the "FOREACH" that i want. we have up to 300 layers in each dwg that need this done
    (if (setq s (ssadd)
    (progn
    "AcDb3dPolyline"
    (ssadd sn s)
    (princ "\n .... ")
    (princ (strcat "Number of Polylines changed : "
    (itoa (sslength s))
    (princ)
    Earth
    9,805
    Well, it does work, in certain situations, because it works just fine here on my sample drawing.
    Can you post a sample drawing of yours?
    Earth
    9,805
    Give this a shot.
        (setvar 'ctab lay)
        (setq s  (ssadd)
    	  ss (ssget "_x"
    		    (list
    		      (cons 0 "ARC,LINE,LWPOLYLINE")
    		      (cons 8 "GRUPPEOMRÅDE")
    		      (cons 410
    			    (if	(eq 1 (getvar 'CVPORT))
    			      (getvar 'CTAB)
    			      "Model"
        (if	ss
          (progn
    		       "AcDb3dPolyline"
    	    (ssadd sn s)
    	(princ "\n .... ")
        )					; end foreach
      (princ)
    2015-04
    4
    Works like a charm...
    Great job thanks!
  1. Wanna be an architect
    By hlamyint in forum 3ds Max - General
    Last Post: 2010-08-30, 02:46 PM
  2. I don't wanna see these lines
    By d.dragov157022 in forum Revit Architecture - General
    Last Post: 2008-03-06, 03:55 PM
