The frustration level is getting pretty high here, looking for a tip or trick.
We have an elaborate model with a significant amount of piping in a facility, mostly ductile iron. Now that the model is finished, we are trying to clean it up, add final piping colors (most piping systems are different colors), equipment, etc. The problem is, all of the pipe and equipment in the model was has a hydronic supply system classification. Now I need to put renderings together. Fixing the materials for mechanical equipment is easy, (just changed the material in the family). Problem I am running into now, is I can't:
1) change system classifications for piping and fittings already modeled to assign materials to the piping system (greyed out in the properties box)
2) paint tool doesn't seem to work with my pipes, fittings, or valves (I open paint material browser, select a material, hover over pipe, it looks like it should select, click, nothing happens). Unable to select any pipe fittings or accessories w/ paint tool.
Any thoughts are appreciated. At this point, I think the tedious task of painting pipe & fittings would be most straightforward. Why doesn't this work?!
Running Revit MEP 2016
Thanks!
