Thread: Bim level 2 DWT file
    2011-08
    Default Bim level 2 DWT file
    Hi Guys
    Im in the middle of setting up a DWT for bim level 2 to try and facilitate the transfer of layers between Revit and Autocad. Are any of you doing the same thing? if not how are you handling the layer names and the transfer between Autocad and Revit. Also how are you handling the blocks and dynamic blocks and there naming conventions
    Director of Operations David Harrington's Avatar
    2000-10
    Tampa, Florida
    416
    Default Re: Bim level 2 DWT file
    For exporting out to DWG I used a very verbose table in the Modify DWG/DXF Export Setup dialog. Example, Floor_CommonEdges. Then in AutoCAD have a very long, DWS listing every element type in Revit and how that layer should be renamed and often bundled into a more abridged layer list in AutoCAD.
    For importing, basically, not allowed. Importing a DWG into Revit brings so much junk that we avoid like the plague.
    Lastly, it isn't hard to rename blocks via SCR or LSP in AutoCAD to whatever standard you have to follow.
    Take care,
    David Harrington
    AUGI Director of Operations
    All AUGI, all the time Liamnacuac's Avatar
    2016-01
    Earth
    508
    There is a third party program called Ideate Bim Explorer that can help clean up and prevent this glut of data being dumped intro a model. Might be just what you're looking for.
  1. 2012: Turn off the section tags and level lines all at once in sheet file
    By diesellam in forum Revit Architecture - General
    Last Post: 2012-07-09, 11:29 PM
  2. Level based Room schedule in Host file
    By pfaudler in forum Revit Architecture - General
    Last Post: 2010-03-29, 11:16 AM
  3. Schedule / Filter by Level with Linked File
    By ppaige in forum Revit Architecture - General
    Last Post: 2009-03-31, 03:08 PM
  4. Replace the .ctb file at the folder level
    By cadd4la in forum VBA/COM Interop
    Last Post: 2006-01-31, 11:57 PM
  5. Can't Rename a Level without crashing the file
    By bmarler in forum Revit Architecture - General
    Last Post: 2005-04-01, 07:36 PM
