Results 1 to 7 of 7
Thread: Connect Block to rectangle lisp
    2009-10
    262
    Default Connect Block to rectangle lisp
    (Defun:Rectest ()
      (if
        (and (SETQ PT1 (GETPOINT "\nPick lower left corner of window: "))
    	 (setq pt2 (getcorner pt1 "\nPick upper right corner of window: "))
         (progn
           (command "_rectangle" "F" ".0625" "W" ".0625" pt1 pt2)
           (setvar 'osmode osmode)
      (SETQ PT3 (GETPOINT "Pick Detail Callout Location: "))
      (command "_.insert" "Detail Callout" PT3 "" "" "" Sheet# Detail# "")
    Would anyone be able to help me do something in my code... i'm a little stumped in how to proceed...
    I'd like to have this code draw a line automatically, without further input, (two lines if necessecary) from the closest point on the circle (Detail Callout) to the rectangle that was just drawn
    though i would like the line to connect only in a perpendicular manner to the rectangle, (At least 1/4" away from the corners of the rectangle) like the pictures attached.
    Attached are the sample pictures, lisp, and block.
    2009-10
    262
    Default Re: Connect Block to rectangle lisp
    While I understand this may be a lot to ask if anyone has an application i can reference that does something similar it would be greatly appreciated
    2008-05
    Yardley, PA
    305
    It's been awhile for me, and if not sure if this would save any time than drafting it.... You could you have it stop and ask the user where to insert the callout, save that point or have it directly start drawing the line from that point and then stop for user input again and say say where do you want to terminate the line and then there you go...
    anyway. not sure if writing this would be any quicker than just drawing it....
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by mbrandt5 View Post
    Here is a very quick stab at it (modified your code).
    I used layers and a block I use, but kept your rectangle line width settings.
    (National Cad Standards layers and block)
    This only places a line to the bubble perpendicular to the right side of the rectangle, all at a scale of 1:1.
    It prompts you to fill in the attributes.
    Hope this helps you on your way.
    I may improve on this for my own needs an pe-post later.
    (Defun:Rectest ()
    (setq cmde (getvar "cmdecho"))
    (setq osm (getvar "osmode"))
    (setvar "cmdecho" 1)
    (setvar "attreq" 1)
    (setvar "attdia" 1)
    (setq la (getvar "clayer"))
    	(SETQ LR1 (TBLSEARCH "LAYER" "G-ANNO-SYMB"))
    	(SETQ LR2 (TBLSEARCH "LAYER" "G-ANNO-SYMB-DETL"))
    		(IF (= LR1 NIL)
    		(command "layer" "make" "G-ANNO-SYMB" "color" "3" "" "lw" "0.35" "" ""))
    		(IF (= LR2 NIL)
    		(command "layer" "make" "G-ANNO-SYMB-DETL" "COLOR" "14" "" "lw" "0.7" "" "LT" "HIDDEN2" "" ""))
    (command "layer" "t" "G-ANNO-SYMB-DETL" "S" "G-ANNO-SYMB-DETL" "")
    (setvar "osmode" 0)
      (if
        (and (setq pt1 (getpoint "\nPick lower left corner of window: "))
         (progn
    (setq pt3 (getpoint "Pick Detail Callout Location: "))
    (setq px4 (car pt2))
    (setq py4 (cadr pt3))
    (setq pt4 (list px4 py4 0))
    (command "layer" "t" "G-ANNO-SYMB" "S" "G-ANNO-SYMB" "")
    (command "_.insert" "NCS_DETL" pt3 "" "" "")
    (command "line" pt4 pt3 "")
    (setvar "osmode" osm)
    (setvar "clayer" la)
    (setvar "cmdecho" cmde)
    2009-10
    262
    Thanks i greatly appreciate it...
    For the time being I just used the pline command
    as part of the code.
    If the block isn't inserted with the base point on the side nearest the rectangle it would overlap.
    Also if its not perpendicular to the rectangle it wouldn't connect.
    2005-06
    3,507
    You're welcome, glad I could help.
    You have a good idea, instead of trying to automatically connect the bubble to the rectangle with line/pline..
    It may be better (easier) to simply have code prompting to draw a pline from the rectangle to the bubble.
    I may do that for my own self
    [cheers]
    2005-06
    3,507
    Inspired by the OP, here is my updated routine that works for my needs and at the company I work for.
    Similar to the code "mbrandt5" started with and what I posted earlier, but this also:
    • Asks what scale to be drawing at (1 = PS, 48 = 1/4" = 1'-0", 96 = 1/8" = 1'-0" etc.)
    • Rectangle has a plinewid of 0 (lineweight ByLayer) and radius of 1/4"
    • After placing the detail call out, draws a polyline (you pick 3-points)
    • Loads the callout "block" from a known address
    ;; DETAIL RECTANGLE AND CALLOUT ROUTINE
    ;; 2016-05-20 TED G.
    ;; CREATES NCS LAYERS AND USES NCS DETAIL CALLOUT
    (defun C:detb ()
    (setvar "attreq" 1)
    (setvar "attdia" 1)
    (setq scl (getdist "What Scale is this being drawn at? (paperspace = 1) Type a Number! "))(terpri)
    (setq rad1 (* 0.25 scl))
    		(IF (= LR1 NIL)
    		(IF (= LR2 NIL)
    		(command "layer" "make" "G-ANNO-SYMB-DETL" "COLOR" "14" "" "lw" "0.7" "" "LT" "DASHED2" "" ""))
    (setvar "osmode" 0)
      (if
         (progn
           (command "_rectangle" "f" rad1 pt1 pt2)
    (command "-insert" "c:\\lisp\\NCS_DETL""scale" scl pt3 "")
    (setvar "osmode" 643)
    (command "_pline" pause pause pause "")
    (princ)
    (princ "\nDETB.lsp loaded, command: DETB, see command line for prompts")
  1. Lisp for rectangle
    By RRS1987 in forum AutoLISP
    Last Post: 2011-10-24, 02:58 AM
  2. Replies: 3
    Last Post: 2009-04-15, 07:30 PM
  3. Can pipes connect to the Face of a rectangle box?
    By Spell in forum AutoCAD Civil 3D - Pipes
    Last Post: 2009-01-21, 06:30 PM
  4. create an excel of block attributes from within a specified rectangle
    By christopher.r.schroll in forum VBA/COM Interop
    Last Post: 2008-05-20, 02:33 PM
  5. LISP to calculate area of rectangle
    By Rynakor in forum AutoLISP
    Last Post: 2006-06-20, 01:15 PM
