Thread: Working with sheet set in ACAD 2014 via VBA
    2016-05
    2
    Default Working with sheet set in ACAD 2014 via VBA
    Hi to everybody!
    I'm trying to start working with sheet sets for long time, but whatever I do my codes don't work.
    Does any one have a working sample to help me? Thanks.
    Turlock, CA
    6,409
    Default Re: Working with sheet set in ACAD 2014 via VBA
    Welcome to AUGI. Try this old AU class. If you want help with your code, provide more information.
    C:> ED WORKING....
    LinkedIn
    2016-05
    2
    Thank you very much! That helped! But could you explain why the enumerator during "Do While Not oPropVal Is Nothing" cicles gives me the same sheet data for 33 times for each sheet? And how to change such sheet properties as revision nuvber and date? Thanks!
    Turlock, CA
    6,409
    Sorry, I haven't worked with that api before. You might try searching this forum first to see if anyone else has posted code.
    C:> ED WORKING....
    LinkedIn
  1. Issue when going from acad 2012 to 2014 loading a .fas file
    By jarod.tulanowski in forum AutoLISP
    Last Post: 2014-03-21, 06:47 PM
  2. ACAD 2014 Plotting Rotated
    By GreenMan415 in forum AutoCAD Plotting
    Last Post: 2013-10-02, 10:10 PM
  3. 2014: old basic lisp not working
    By Coloradomrg in forum AutoLISP
    Last Post: 2013-08-02, 03:45 PM
  4. 2014: Acad 2014 and layer windows
    By Jimbob in forum AutoCAD General
    Last Post: 2013-08-01, 06:50 PM
  5. 2014: RPC's not working in Revit Architecture 2014
    By julian.karate367860 in forum Revit Architecture - General
    Last Post: 2013-03-29, 01:40 AM
Tags for this Thread
