Hi guys can anybody knows... How to remove the errors from multi .dwg files at same time. Because I have more than 200 dwg files and each file has 55mb to 350mb in size. which is normally not possibl. I believe this because of some errors in file.. And I tried to remove the error by using purge, audit, dxf format, and dgnpurge methods. After these methods now the file size is showing 5 to 10mb. But one of big problem is that inside the dwg file attached images are not appearing but links are as its. When I reattach the image by reference manager and remove the xreference from dwg the the file size getting same as 50 to 350md. And its taking too much time to do one by one..... Can anybody solve this issue... I need to remove multi files errors and reduce file size at same time. Any help will be more appropriated....
Thanks
