Any particular reason why one cant select lines that create an enclosed area to create a filled region? similar to the boundary command in ACA.
thanks.
thanks.
not sure what you are trying to do here exactly, but you can select existing lines (or elements) to create your filled regions.
you can also "lock" the lines to the elements edges so that if it changes, or moves the filled region moves with it.
Use the little green arrow option (pick line) in the type of line you wish to draw, once you open up the filled region command.
Use tab to select chains of lines
