Hi all,
I have created an elevation dynamic block that has a flip action. when I use the flip action or if I mirror the block the left/right alignment gets messed up. If you edit the attribute the alignment will change and if you explode the block after flipping you can see how the alignment has changed. My question is how can I keep the text alignment correct when I flip or mirror the block. block is attached.
thanks,
Kevin
