I recently toyed with our titleblock to see about making it print the same size if plotting the drawing from a PDF file as it would if printing straight from autocad.
I got it very close, but shows a very slight discrepancy like .25mm or less at the far end of the printed scale on the drawing, from the PDF file. Just curious if this slight difference is anything that can be corrected by further working with titleblock, or if it's due to PDF plotting differently than autocad.
PDF version shows slightly fuzzy linework etc compared to autocad so for now I'm assuming it's something I may not be able to fix.
