Results 1 to 1 of 1
Thread: Filled Regions not Printing
    2011-06
    28
    Default Filled Regions not Printing
    I have an issue which is probably tied into the PDF driver / creator, but is also a general Revit problem from what I can tell.
    Here is the set-up:
    In version 2013, I encountered a problem where filled regions were printing in some floor plans, but not in others. Weird, because they all used the same view template.
    Fast forward a few years to version 2015...
    Our office will design and document a high-rise project in Revit 2015. We are using a second file to deal with repetitive dimensioning and the graphics for shaft-openings.
    This file is linked into the main file, and a referenced view is applied the view filter.
    I go to print...and...the filled regions are not displaying properly. (In fact, displaying exactly as they did in my 2013 project.)
    In the 2013 project, it only affected a handful of sheets, so I was willing to let it slide. In this project, it will apply to hundreds of sheets.
    This is not acceptable.
    Raster-printing is also unacceptable.
    Can anyone recommend either a PDF printer, or some quirky places where this error is hiding?
    See images below.
  1. 2012: Filled Regions
    By augisouth696974 in forum Revit MEP - General
    Last Post: 2013-05-01, 01:37 PM
  2. Printing Filled Regions within Families
    By guy.messick825831 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-03-25, 04:38 PM
  3. Filled regions converting to masking regions
    By GS Fulton in forum Revit Architecture - General
    Last Post: 2007-06-06, 06:12 PM
  4. FILLED REGIONS
    By dpasa in forum Revit Architecture - Wish List
    Last Post: 2005-10-08, 04:11 PM
