Good evening,
I am trying to change the phase filter to Show All in a 3D view using the API. However it seems i can't set the parameter even when it return True.
The value of the phase filter parameter remains the same after running the script.
What am i doing wrong?
If it's impossible to change the phase filter, is there a way to import a viewtemplate from another file and apply that to a 3Dview?
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace test
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("0C4DCB69-0A65-4FE4-9269-63E62D661120")]
public partial class ThisDocument
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void test12()
UIDocument uidoc = Application.ActiveUIDocument;
Document doc = uidoc.Document;
FilteredElementCollector collector = new FilteredElementCollector( doc ).OfClass( typeof( View3D ) );
foreach( View3D v in collector )
msg(v.Title.ToString());
Parameter param = v.get_Parameter(BuiltInParameter.VIEW_PHASE_FILTER);
msg(param.AsValueString());
msg(param.Set("Show All").ToString());
public void msg(string message)
TaskDialog.Show("debug", message);
