Thread: How to handle Unresolved References dialog
    2016-06
    5
    Default How to handle Unresolved References dialog
    Hello!
    How can I automatically ignore unresolved references when opening a project file?
    I tried using the DialogBoxShowing event which triggered but I wasn't able to close this dialog.
    e.OverrideResult(result) does not work with any result.
    104
    Default Re: How to handle Unresolved References dialog
    Here is how I do this one:
    		public void Project_DialogBoxShowing(Object sender, DialogBoxShowingEventArgs args)
    			TaskDialogShowingEventArgs args2 = args as TaskDialogShowingEventArgs;
    			if (null != args2)
    				string s = args2.DialogId;
    				//MessageBox.Show("Dialog ID is:  " + s);
    				if (args2.DialogId == "TaskDialog_Audit_Warning")
    					args.OverrideResult((int)TaskDialogResult.Yes);
    				if (args2.DialogId == "TaskDialog_Unresolved_References")
    					// Buttons with custom text have custom IDs with incremental values
    					// starting at 1001 for the left-most or top-most button in a task dialog.
    					// "Open Manage Links to correct the problem", "1001"
    					//args2.OverrideResult(1001);
    					// "Ignore and continue opening the project", "1002"
    					args2.OverrideResult(1002);
    2016-06
    5
    It worked perfectly, I didn't use TaskDialogShowingArgs.
    Thank you for the quick reply.
    2012-01
    peterjegan, I tried this code but received this error in Visual Studio: 'DialogBoxShowingEventsArgs' is inaccessible due to its protection level
    Any help is greatly appreciated!
    Thanks.
  1. File keeps throwing up Unresolved References error
    Last Post: 2010-09-02, 05:51 PM
  2. Unresolved Xref
    By asmckee in forum AutoCAD General
    Last Post: 2010-03-19, 06:52 AM
  3. xref unresolved
    By crbickel in forum ACA General
    Last Post: 2007-03-28, 12:12 AM
  4. Unresolved References.
    By amey in forum Inventor - General
    Last Post: 2006-03-16, 11:35 AM
  5. Unresolved Xref
    By Shizzjr in forum AutoCAD General
    Last Post: 2005-12-19, 05:17 PM
