Anyone unable to export to Navisworks from 2017? Mine seems to crash every time. I'm going to try different models to see if it is model-specific.
Just got this to work on the fourth try - not sure what is going on with this.
Has anyone found out what is happening?
There's really not enough information to answer this properly. Two options come to mind immediately. The computer runs out of RAM while processing or your hard drive may be full, so it just crashes when it tries to write data to the disk. RAM seems the most likely.
Be sure to clean out your Windows scratch disk after every program crash: Start > run > %temp%
I agree with Brian, you definitely want to make sure you have enough free disk space.
Consider upgrading your video card driver to the latest one.
Brian, I have a Dell workstation with 32 gb ram, xeon processor, Nvidia Quadro of 4.0 gb and solid hard drive disk with 320 gb available!!
Then what is the problem when I export to Naviswork? Because with revit 2016 I can do it.
- - - Updated - - -
