Thread: Revit 2017 won't start
    2006-04
    149
    Default Revit 2017 won't start
    The last two days, I have prepared my laptop to download & install Building Design Suite 2017. I uninstalled all previous versions of all my Autodesk products. I then performed a defrag on my main hard drive, Then, because I eventually want to get Windows 10 before the free deadline is up, I upgraded my IE to 11. I then downloaded and installed the Building Design Suite and all the available updates. I was able to get through the activation process with my seriel number. However, now when I launch any program from the design suite, it immediately crashes!
    I have repaired the Microsoft.Net Framework, I have repaired the Revit installation, and I have upgraded the drivers on my video card.
    Has anybody else encountered this issue? Does anybody know of any solutions? I've been searching the internet and have not found any yet.
    I appreciate any and all help.
    Tom
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Re: Revit 2017 won't start
    I would try this process:
    https://knowledge.autodesk.com/suppo...DC6B1-htm.html
    If it doesn't work after that, I suggest submitting a case to Autodesk Support.
    2006-04
    149
    Thanks for the reply Brian. I actually followed those steps last year, because I had a similar problem when I installed Building Suite 2016. However, after consulting a few others, including the man who built my machiine, the consensus is that during the process of uninstalling, defragging etc. my Windows install has been corrupted, and I was advised to wipe the machine and reinstall everything!
  1. 2017: Revit 2017 is Available Now
    By Steve_Stafford in forum Revit - Platform
    Last Post: 2016-12-03, 06:24 AM
  2. 2017: Revit 2017 Viewcube keeps disapearing
    By Anthony@LDG in forum Revit - Platform
    Last Post: 2016-09-03, 07:34 PM
  3. 2017: Revit 2017 install error message
    By salaaaah_2010729743 in forum Revit MEP - Families
    Last Post: 2016-06-11, 03:53 PM
  4. 2017: Install problems with Revit MEP 2017
    By mickaeL_renauD in forum Revit MEP - General
    Last Post: 2016-05-27, 01:09 PM
  5. 2017: Depth Cue for Revit 2017
    By Mike@ADa in forum Revit Architecture - Tips & Tricks
    Last Post: 2016-04-18, 09:08 PM
