Keep copied items exactly as they are
Summary: Keep copied items that have graphic over rides the same.
Description: If you copy an item that you have put a graphics over ride on, it should stay with the graphics override.
Example - you have a column that you want to show up as a dashed line so you over ride the element . You realize you need 2 of them so you copy it. Since you are wanting the exact same item, with the exact same graphics over ride, they should copy the same without having to go in and redo the over ride for THAT column as well.
Product and Feature: Revit Architecture - Other
Submitted By: clair_brodie on 07/21/2016
- You may not post replies
- You may not edit your posts
Forum Rules
