Thread: Where to find the ShrinkWrap command?
    I could stop if I wanted to CadDog's Avatar
    So Ca
    439
    Default Where to find the ShrinkWrap command?
    Is this command still around...???
    I prinked out "AutoCAD 2005 Tips & Tricks by Andrew Manninen"
    It has a lot of great little tips but I couldn't find ShrinkWrap anywhere...
    I'm using AutoCAD 2006 now and wanted to know if ShinkWrap is still around or
    has it change it name...
    I really like the idea of selecting an Arch building drawing and create a pline boundary of the outside with two steps...
    So Ca
    439
    Default Re: Where to find the ShrinkWrap command?
    Sorry anyone...
    I found it...
    Google is so Cool...
    In was in:
    Autocad 2005 version with Civil LandDesktop
    Thanks anyway...
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    I figured out where shrinkwrap went to.
    When objects are selected, it can be found on the right-click menu in LDT.
    The command is _aeclineworkshrinkwrap (you have to include the leading underscore). I confirmed that the command works in LDT, Land Enabled Map and Civil 3D in the 2006, 2007 and 2008 versions. It probably works in Architectural Desktop too.
    2003-12
    Pittsburgh, PA
    355
    This thread has a lisp application that works similar
    http://www.cadtutor.net/forum/showthread.php?t=14493
    2015-11
    4
    Thanks Jeff. I'm using Civ 3d 2015 and couldn't remember a co-worker using this to create a single boundary from tree canopies (just a single boundary from many bubbles).
    I got the command to work as lineworkshrinkwrap
  1. SHRINKWRAP (Reinstating & improving the Shrinkwrap Command)
    Last Post: 2013-12-02, 02:02 PM
  2. 2012: Find/Replace command help
    By dmusika in forum AutoCAD General
    Last Post: 2012-10-16, 05:12 PM
  3. FASTSELECT command, can not find any help on it
    By clarkrj in forum AutoCAD General
    Last Post: 2006-06-13, 01:55 PM
  4. FIND & ZOOM TO VIA COMMAND LINE *
    By autocadinstructor in forum AutoCAD Wish List
    Last Post: 2005-04-06, 09:06 PM
  5. Find and Replace Command
    By son.do in forum AutoCAD General
    Last Post: 2005-01-31, 10:40 PM
