Been trying to create a pretty simple exterior monolithic stair.
Everything seems to work as usual, but when complete, a portion of the stair is invisible in 3d view. In plan, its all there (although if tab selected, it cycles through a stair version with the two halves, upper and lower, and a full stair version. I can delete the full version, the halved version ignores the delete command). Photos attached, all of the visibility settings are set up normally. If I change the stair family type to precast, same thing, if it is set to any other standard assembled stair, the stair is visible as normal with no partial visibility.
Anyone have this issue or know what may be going on?
