I have a task to bring PDF's into AutoCAD 2017 and modify.
Is RASTER the tool to use for MODIYINF or is it even possible?
Thanks
Al
Thanks
Al
Are you just underlying the PDF's or using PDF to DWG converter?
I'm trying to use the PDF to DWG converter and then remove objects.
there're many free tools available for converting PDF files to DWG or DXF format which you can import and modify in AutoCAD .
You may also benefit from AutoCAD 2017 new Import as Objects tool from the PDF Underlay ribbon tab. You can then import everything or pick a polygonal or rectangular selection around the geometry you want to import and edit as native cad objects.
I have been trying that but I just noticed a message that states AutoCAD can't find a "aeciimui60.arx" dll. What's the problem?
