Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Create a Selection set from Civil 3D point group or point description.
  1. #11
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Create a Selection set from Civil 3D point group or point description.
    Thanks for the advice, tips, and book recommendations. Time to learn at the moment is limited. I would like to move to, well actually just add, .NET to my toolbox. I know enough to put together some .NET, but am not comfortable enough to run through as I am LISP.
    And the post merge thing, wait a few minutes between posts. I know, it seriously throws a monkey wrench in the works when you are on a roll. Sorry.
  2. #12
    2009-11
    5,719
    What little wisdom I've been able to accrue, I'm happy to share.
    What I neglected to mention, is that learning .NET can easily be an exponential curve.
    That is to say, that once you learn X, learning Y, and Z are even quicker to learn, which themselves make subsequent tasks even easier. Inheritance based polymorphism is the first thing that tends to blow a LISPer's mind, and is a Godsend, frankly (sounds way more complicated than it really is). Haha
    The next might be Method Overloads... 'What do you mean I can have the same 'Defun' with different arguments!?' Ehhhehehe
    Grrrr... You know, if I were coding that functionality, I'd implement a character length logic test, if less than the max, then append as a post update, else create a new post. Haha #JustSaying
    Cheers
    Computer Specs:
  3. #13
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    This was a long thread and I didn't read the whole thing so I apologize if this has already been mentioned.
    You can created a group by description matching then right-click on the point group in the prospector and choose select from the menu.
  4. #14
    2015-10
    73
    Hello BlackBox, I'm reading through this thread in an effort to find a way to list C3D points by a selection set. Is that the intent of the LISP you wrote here? Does C3D have the ability to list a set of points by "window"? Am I overlooking the obvious?
    TIA
  5. #15
    2015-12
    Arizona
    2,478
    create your selection set, then run the points list report, and use P, for Previous to define the desired points to list.
    and or use a point group
    Last edited by BlackBox; 2021-05-20 at 04:50 PM. Reason: Added line breaks before image for better formatting.
  6. #16
    2009-11
    5,719
    Quote Originally Posted by rickquin651723 View Post
    TIA
    What a long thread to try and read through; I had way too much to say back then.
    Let's start with what do you mean by 'list C3D points by a selection set'... As in, select some COGO Points (various Point Groups, Styles, Layers, etc), then right click, select 'Edit Points...' menu item?
    Computer Specs:
  7. #17
    2015-12
    Arizona
    2,478
    Quote Originally Posted by BlackBox View Post
    that and then a 'copy to clipboard' if one needed an output...
  8. #18
    2015-10
    73
    Well, back in the day when I used Eagle Point, I could just do a crossing window and it would grab all the points within that window and ignore all the other geometry inside the window. I think it even told you how many nodes it found, which would be handy for this new drill I'm having to do. We have a new client with new needs!
    "I had way too much to say back then."........That's funny, I don't care who y'are
  9. #19
    2015-12
    Arizona
    2,478
    create point group
    selection set in drawing does that....
    I also guess that Jeff could make a tool do mimic that functionality without use of the group
  10. #20
    2015-10
    73
    I'm starting a new project and I'm gonna give your "report method" a whirl, I'd forgotten about that. I'm having to keep numbers on specific points in very specific places. In my 1st go-'round I overlooked a point and it cost me hours. Thanks, mjfarrel
  1. 2014: Description Key Sets - Moving Points to the correct Point Group
    By Iceberg in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-03-11, 04:09 PM
  2. Civil 3D 2009 point group question
    By villalobosg in forum AutoCAD Civil 3D - General
    Last Post: 2008-12-18, 03:07 PM
  3. Picking points in order to create a point group in Civil 3D 2007
    By wcarter in forum AutoCAD Civil 3D - General
    Last Post: 2006-11-03, 08:34 PM
