Results 1 to 8 of 8
Thread: export layout to model
    2004-06
    Slidell, Louisiana
    972
    Default export layout to model
    I need to send the client a cad file but don't want to send them the entire file which is huge.
    I tried export layout to model, but after 25 minutes it finally said "* EXPORTLAYOUT failed to generate a new drawing. **"
    I ran audit and recover and recoverall prior to running the command.
    is there any other way of generating what i am looking for.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: export layout to model
    Did you promote all data references and bind all xrefs beforehand?
    Also, that command creates a new drawing based on the layout's coordinates. Therefore, if you need them to remain at the original coordinates, you will need to scale/align the generated drawing back to the original coordinates.
    2004-06
    Slidell, Louisiana
    972
    The dwg has no data references or xrefs and is a little bit over 8 MB in size.
    Cairo - no, not Illinois
    5,069
    try ExportToAutoCAD _first, and then try to export the layout to model
    2004-06
    Slidell, Louisiana
    972
    tried exporttoAutocad, saved as a 2010 version. made the file 135 mb in size. opened in vanilla Acad2016-ran export layout to model.
    only took 3 min. to come back as a failure compared to 30 min. using C3D2016, but still a failure. GRRRR!!!
    5,069
    with the vanilla (2010) version of the dwg, run the 'Civil3d as AutoCAD' shortcut to avoid loading any AEC cruft into the drawing,
    oops, reading failure. Purge and audit in vanilla? purge regapps?
    2008-02
    North Liberty
    60
    I learned you can reduce file size by 'blocking' features in model space. So block similar features and see if it reduces the size.
    2013-01
    Hello my friends
    When I get AutoCAD export from Civil3d , link between the model and layouts is lost and gives me some AutoCAD files.
    For example, I have a map in Civil3d with four layout
    When I get the export I get five dwg files
    I want to give an output file and the link between the model and layouts is not lost.
  1. Export Layout Tab Names
    By avdesign in forum AutoCAD General
    Last Post: 2019-05-22, 04:21 AM
  2. Export Layout Tabs to drawing files
    By andy in forum AutoCAD Customization
    Last Post: 2015-10-08, 01:27 PM
  3. Layout export
    By Marco-Rome in forum AutoCAD Plotting
    Last Post: 2011-07-26, 06:53 AM
  4. Export layout as a new model.
    By mAnOO in forum AutoCAD General
    Last Post: 2010-10-11, 05:12 AM
  5. Import and Export Model or Layout Views
    Last Post: 2008-02-05, 08:01 PM
