Thread: tiff file is not transparent
    4
    Default tiff file is not transparent
    The tiff file comes in with a white back ground when I attach it to the drawing. I have tried changing the property settings to no avail. Any ideas?
    9,805
    Default Re: tiff file is not transparent
    The TIFF needs to be bitonal, or 1-bit. IOW- each pixel should be on or off.
    More info: http://forums.augi.com/showthread.ph...nd-transparent
  1. convert .tiff file to .dwg file
    By cobra1964 in forum AutoCAD General
    Last Post: 2008-07-16, 03:56 PM
  2. Insert image file (TIFF) into an AutoCAD drawing file
    By snorcisa in forum AutoCAD General
    Last Post: 2007-04-15, 09:51 AM
  3. Replies: 3
    Last Post: 2006-12-14, 08:12 PM
  4. Some TIFF's not showing as transparent in PDF
    By Maverick91 in forum AutoCAD Plotting
    Last Post: 2006-07-04, 01:05 PM
  5. Attaching a tiff file
    By MikeM4OSU in forum AutoCAD General
    Last Post: 2005-07-18, 01:23 PM
