Thread: Set page aetup for more than one page in single layout.
    2016-08
    6
    Default Set page aetup for more than one page in single layout.
    I have a single layout in which there are multiple viewports and I want to print pdf of that all pages so there is any way so I can set all that viewports as my setup page?
    Turlock, CA
    6,420
    Default Re: Set page aetup for more than one page in single layout.
    A layout can only have one page setup. Rather than coding a solution for the layout you have, it would be better for you to design multiple layouts. Then you could use a sheetset to plot all the layouts. Just copy the layout as many times as you have viewports, then delete the unwanted stuff from each page.
    C:> ED WORKING....
    LinkedIn
    2009-11
    5,719
    I'm with Ed on this; just use a single drawing with multiple Layouts, or multiple drawings with single-Layout.
    Either way, this may help you to set the active Page Setup for all of your Layouts for both of the above configurations, as it can be used on all Layouts within a drawing, or on multiple drawings via ObjectDBX:
    http://forums.augi.com/showthread.ph...=1#post1317124
    Cheers
    - - - Updated - - -
    Just realized that his was in the .NET forum; if you follow the links, I've posted the C# source code; take from it what you like.
    Computer Specs:
  1. 2011: Layout Tab Page saving to PDF
    By Detsenira in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-09-23, 04:23 PM
  2. Layout Page Number
    By kwest in forum AutoCAD LT - General
    Last Post: 2009-03-27, 01:29 PM
  3. Single sheet publishing thru page setup override
    By aleksandarm in forum AutoCAD Sheet Set Manager
    Last Post: 2007-06-09, 11:42 PM
  4. Multiple Sheet Plot to A Single Page
    Last Post: 2007-01-09, 05:23 PM
  5. OLE Word file - single page only?
    By CADMama in forum AutoCAD General
    Last Post: 2006-08-17, 03:55 AM
