I created a 3-sided W-beam frame using Frame Generator.
I mitered the first joint with no problem. I then wanted to notch the second joint replicating angles that a band-saw can accomplish.
I am able to miter the second joint, but that creates an acute angle of 22.5 deg, which a typical band-saw cannot do.
I would like the vertical beam to be notched into the horizontal beam, with a 45 deg cut.
The horizontal beam would just be cut to length on a band-saw at a 45 deg angle.
I have tried every scenario I can think of with the Notch tool (and other tools) but can't seem to get the results I want.
Any help would be greatly appreciated. Thanks
