Thread: how to export dynamic blocks form Autocad Architecture to AutoCad ?
    2016-02
    Default how to export dynamic blocks form Autocad Architecture to AutoCad ?
    i am making a small bib in autocad.
    i have to make dynmaic blocks and is there a way to export all components from atucoad architectur to Autocad 2017 ?
    tnx
    2003-03
    Philadelphia, PA
    2,392
    Default Re: how to export dynamic blocks form Autocad Architecture to AutoCad ?
    AutoCAD Architecture is built on top of AutoCAD. Any Dynamic Block you create in AutoCAD Architecture should work the same in vanilla AutoCAD.
    AutoCAD Architecture objects do not play nicely in Dynamic Blocks. Are you trying to incorporate something created with AutoCAD Architecture objects in a Dynamic Block? If so, post back indicating what type(s) of AutoCAD Architecture objects you are using, and someone here may be able to offer advice on how to convert them to an AutoCAD object.
  1. GD12-3: Go Dynamic: How to Create Dynamic Blocks in AutoCAD 2006
    By Autodesk University in forum General Design
    Last Post: 2013-04-17, 04:17 AM
  2. AutoCad Architecture 2010 Schedule Export
    By mhibbitt in forum AutoLISP
    Last Post: 2011-04-08, 06:34 PM
  3. export en dwg, passage revit en Autocad architecture
    By marounkhattar in forum Revit Architecture - General
    Last Post: 2009-10-27, 05:18 AM
  4. Dynamic Blocks in AutoCAD Map
    By nightNday in forum Dynamic Blocks - Technical
    Last Post: 2008-07-25, 05:58 PM
