Thread: Language change not working
    2013-05
    3
    Unhappy Language change not working
    Hi,
    I'm trying to make my Revit UI Japanese, and I have installed the Japanese version of Revit. However, only a few parts of the UI change language, and this is the same whatever language I choose in the shortcut. Here's a screenshot showing roughly which parts of the UI get translated.
    Does anyone know what could be causing this?
    The system language of the computer I am running it on is also Japanese, so I am stumped on what could be causing this. I tried it on another computer and it has the same problem. Is this a Revit 2017 issue?
    Many thanks,
    Shogo
    2006-05
    Seattle, WA
    180
    Default Re: Language change not working
    Try this: https://knowledge.autodesk.com/suppo...EBD6C-htm.html
  1. 2013: [URGENT] Change Revit Schedule Display Language?
    By ng_ph_long293217 in forum Revit MEP - General
    Last Post: 2013-02-06, 08:24 AM
  2. Working process and enviroment change
    By Josue Silva in forum CAD Management - General
    Last Post: 2007-08-01, 07:41 PM
  3. Change the other Language text to English
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-03-27, 04:52 PM
  4. Language change
    By JustJimmy in forum AutoCAD Map 3D - General
    Last Post: 2005-05-19, 02:28 PM
Tags for this Thread
