Thread: switching from AutoCAD to Revit
    2016-09
    Angry switching from AutoCAD to Revit
    so i have been messing with trying to make a base Revit file, that will keep all the settings that are set in my AutoCAD files. mainly layers and their settings. although i am having trouble figuring out exactly how to go about this. i have tried editing the export settings, as well as linking in a file and editing in the object styles dialog box. i read an article about a .txt file being able to help but i could not find the correct file to start from in the program files, nor could i find any kind of formatting for the .txt file to try and start from scratch.
    for my final outcome to summarize i am needing to be able draw in revit, but when exported to AutoCAD have all the layers remain how they would be as if it were to have been done in AutoCAD. i know there has to be a way to do this, but have hit a road block on what to try next.
    thanks in advance for any help.
    in the upper right corner
    3,508
    Default Re: switching from AutoCAD to Revit
    Look into Exporting to Autocad options, you can map and save Exports to desired layers. If I recall, it defaults to AIA/NCS type layer names, but it's not perfect or pretty.
  1. Replies: 0
    Last Post: 2015-08-07, 03:47 PM
  2. If AutoCAD 2010 crashes when switching workspace
    By andrew.handley782323 in forum AutoCAD Customization
    Last Post: 2010-06-14, 08:33 PM
  3. Problems with Switching to Revit from AutoCAD?
    By tedg in forum Revit - In Practice
    Last Post: 2008-09-12, 04:18 PM
  4. switching to Vista 64 - Revit activation switching
    By ws in forum Revit Architecture - General
    Last Post: 2008-06-08, 10:02 AM
  5. Replies: 2
    Last Post: 2007-01-10, 07:09 AM
