Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Importing hatch pattern from cad into revit
  1. #11
    2016-10
    18
    Default Re: Importing hatch pattern from cad into revit
    Hi thanks for the explanation. But do i really need add-in in order to have my marble.pat loaded correctly in revit?
  2. #12
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    360
    Quote Originally Posted by barlabro14736762 View Post
    No, not at all. I found that both the original and the revised pattern versions readily loaded to Revit 2016 as INCH DRAFTING patterns.
    But to load that pattern as a MODEL pattern (it is very small) you can either
    • edit the pattern to include a line reading ;%TYPE=MODEL just after the line containing *patternname and bump up the scale while reloading it to Revit from the .PAT file
    • use the Add-In to directly create a MODEL fill and rescale it within REVIT without having to edit or reload from the .PAT file
    hth
  3. #13
    2016-10
    18
    Thanks Hugh ill try this one and will give you feedback
  1. 2015: Linked Revit Hatch Pattern Visibility Issue
    By Revit_Struct_User in forum Revit Architecture - General
    Last Post: 2016-03-30, 01:24 AM
  2. 2016: Revit hatch pattern oddity.
    By david.metcalf in forum Revit - Platform
    Last Post: 2015-06-16, 04:57 PM
  3. Hatch/Pattern Editor in Revit
    By Andre Baros in forum Revit Architecture - Wish List
    Last Post: 2014-06-25, 07:46 AM
  4. Revit Earth Hatch Pattern
    By rroswall.242547 in forum Revit - Platform
    Last Post: 2010-02-17, 10:28 AM
  5. Revit Hatch Pattern Decoded
    By Chirag Mistry in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-03-19, 06:07 PM
