Hi all, i have code attached. Im just wondering if it could be done in the same way but instead of "QLEADER" it will be "MLEADER"? I already tried changing the command to mleader but doesn't work the same. Thank you in advance. Cheers!
PS: somehow related to my previous post. Thanks for the help TED.
(setq l_ang 90)
(defun c:q (/ sty nm p1 p2 ateblk p3)
(command "cmdecho" "0")
(setq osm (getvar "osmode"))
(setq ort (getvar "orthomode"))
;(command "osmode" "2")
(setq p1 (getpoint "\nPick origin point"))
(command "osmode" "0")
(command "orthomode" "0")
(setq p2 (getpoint "\nPick target" p1))
(princ)
(if (< (car p1) (car p2))
(progn
(if (< (cadr p1) (cadr p2))
(setq p3d (- (cadr p1) (cadr p2)))
(if (< (cadr p2) (cadr p1))
(setq p3d (- (cadr p2) (cadr p1)))
(progn
(setq p3 (polar p2 (+ 0.0 (dtr (- l_ang))) (* p3d 1.0)))
(command "QLEADER" p2 p3 p1 "" "" "n")
(progn
(setq p3 (polar p2 (+ 0.0 (dtr l_ang)) (* p3d 1.0)))
(if (< (car p2) (car p1))
(progn
(progn
(progn
(command "Qleader" p2 p3 p1 "" "" "n")
(command "osmode" osm)
(command "orthomode" ort)
(defun dtr (a)
(* pi (/ a 180.0))
