Hello all,
The company I am working at has replaced their titleblock a few times over the years for various reasons ie.. logo change, required attribute information changing, etc.. I have cobbled together a lisp routine to
1. update the attribute tags using code from this post
2. export the data into a tab delimited file using modified code from the attout.lsp and calling some functions in that lisp.
3. remove and purge the old titleblocks and replace the the blocks with the updated version.
Now the part I am stuck on is replacing the attribute information. if I use attin i can select the txt file and manually select the files assuming I know what order they were selected in on the extraction. I am currently making my selections with this piece of code. I use this for all the selections throughout the process so it will always select in the same order. I would like to make the selection to replace the attributes the same way.Code:(setq BLKLST(ssget "x" (LIST(CONS 2 "MAR4"))))
as a side note these are multi sheet isometrics with all the sheets in model space.
Any help would be greatly appreciated
