You can export shared parameters to a new shared parameter file if the old parameter file is deleted, or if there are shared parameters in a family or a project that are not in the current shared parameter file.
Before you can export them, you must already have added the shared parameters into a Autodesk® Revit® project file or family file. For more information on adding shared parameters, see
Adding Shared Parameters to Families and
Project Parameters.
- Create or open a shared parameter file according to steps 1 and 2 of the previous procedure. Select a shared parameter in either a family or a project. Click Modify.
- In the Parameter Properties dialog box, click Export.
NOTE: The Export command is never enabled if the selected shared parameter is already in the current shared parameter file.
- An informational message appears informing you that the shared parameter will be exported to the shared parameter file you set up in Step 1.
- Click OK to complete the export.
Project Parameters.
- Create or open a shared parameter file according to steps 1 and 2 of the previous procedure. Select a shared parameter in either a family or a project. Click Modify. In the Parameter Properties dialog box, click Export. NOTE: The Export command is never enabled if the selected shared parameter is already in the current shared parameter file. An informational message appears informing you that the shared parameter will be exported to the shared parameter file you set up in Step 1.
