Thread: Exporting project parameters
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Default Exporting project parameters
    I am wondering if this is possible...somebody wrote over my shared parameters file for my custom titleblock and I am wondering if there is any way to recover the information (which i had saved in another drawing) without having to COMPLETELY recreate it...grr...
    Thanks,
    Danielle
    2001-12
    Irvine, CA
    7,567
    Default Re: Exporting project parameters
    Yes Revit help says:
    You can export shared parameters to a new shared parameter file if the old parameter file is deleted, or if there are shared parameters in a family or a project that are not in the current shared parameter file.
    Before you can export them, you must already have added the shared parameters into a Autodesk® Revit® project file or family file. For more information on adding shared parameters, see Adding Shared Parameters to Families and Project Parameters.
    1. Create or open a shared parameter file according to steps 1 and 2 of the previous procedure. Select a shared parameter in either a family or a project. Click Modify.
    2. In the Parameter Properties dialog box, click Export.
    NOTE: The Export command is never enabled if the selected shared parameter is already in the current shared parameter file.
    1. An informational message appears informing you that the shared parameter will be exported to the shared parameter file you set up in Step 1.
    2. Click OK to complete the export.
    1. Create or open a shared parameter file according to steps 1 and 2 of the previous procedure. Select a shared parameter in either a family or a project. Click Modify. In the Parameter Properties dialog box, click Export. NOTE: The Export command is never enabled if the selected shared parameter is already in the current shared parameter file. An informational message appears informing you that the shared parameter will be exported to the shared parameter file you set up in Step 1.
    2004-06
    Mostly in Mom-land
    704
    Thanks Steve,
    I figured it out and was quite relieved, even said aloud "I love this program".
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by dacree
    ...was quite relieved, even said aloud "I love this program"...
    Glad you did!
    ... and I've heard that before! Every once in awhile, out of the blue, I get an IM from users here, "I Love Revit"! Never fails to make me grin!
  1. 2015: Exporting to Cad by Project Internal
    By david_peterson in forum Revit Architecture - General
    Last Post: 2015-08-06, 05:19 PM
  2. 2014: Criteria for Project Parameters vs. Shared Parameters
    By jagostinho in forum Revit - Platform
    Last Post: 2014-03-21, 02:46 PM
  3. Scheduling Project Information with Shared Parameters in Multi-Building Project
    By ddragoo144336 in forum Revit Architecture - General
    Last Post: 2010-08-20, 05:36 PM
  4. Shared Parameters Not Exporting to ODBC
    By Duffy in forum Revit Architecture - General
    Last Post: 2007-09-25, 10:16 PM
  5. Exporting Shared parameters
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-12-13, 10:18 PM
