Thread: Wall Edit Question
    2015-09
    6
    Default Wall Edit Question
    So, I posted a suggestion in the "Wish list" located here :
    http://forums.augi.com/showthread.ph...-a-curved-wall
    It was closed and stated that it is already part of the software. I am using the latest release of 2016 and as far as i know you cannot edit the profile of a curved wall WITHOUT have to made a void cut or several located off a reference plane NOR can walls clean up to a stair like they do to a ceiling or roof. If i am missing something please let me know otherwise im not sure that my wishlist should be locked.
    thanks for the heads up or ... learn from, which ever this works out to be.
    2015-08
    199
    Default Re: Wall Edit Question
    This response is a little late but the way you are suggesting to do this with edit profile of a wall is essentially impossible unless using pick line to get it to follow a curve slope exactly.
    The way to do this currently is by creating a swept blend sweeping from short wall profile to tall wall profile along the curve and then after you can create a wall by face to get the desired outcome.
    2015-01
    Orlando, Florida
    61
    Thanks, @marmiketin. You're correct. And, sorry @schilds937, you're wish didn't get answered quite correctly. Yes, there are methods to manipulate profiles of curved walls in Revit, using other functions, as suggested by @marmiketin. Some are more advanced than others, but the short answer is that it doesn't exist within the Modify Walls menu, and you need to start from a different place (e.g., Massing).
  1. Able to edit profile on slanted wall while wall face is planar
    Last Post: 2013-08-11, 06:34 AM
  2. 2013: edit family - simple question...yes or no?
    By lucavox91694789 in forum Revit - API
    Last Post: 2012-10-27, 01:07 PM
  3. Wall footing / Edit wall profile
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2010-09-24, 09:51 AM
  4. EDIT IT EDIT WALL JOINS!
    By yishida in forum Revit Architecture - General
    Last Post: 2006-07-07, 05:22 PM
  5. Edit Wall Profile of Angled Wall
    By todd.69291 in forum Revit Architecture - General
    Last Post: 2005-10-28, 05:31 PM
