Bracing work point control
Summary: Provide a way to explicitly define work points when adding bracing elements
Description: Currently bracing work points are not explicitly defined in the input process. The interface is graphical but after trying to select the desire work point, Revit in many case moves the selected point to an arbitrary nearby point. For example if an end point of a girder is close by, then the endpoint of the bracing gets shifted or forced to it.
Product and Feature: Revit Structure - Beams
Submitted By: gamaris on 10/26/2016
- You may not post replies
- You may not edit your posts
Forum Rules
