Thread: Sheets Organization
    2016-10
    12
    Default Sheets Organization
    Hi there!
    I am trying to find out if a project with more than 3 sheets..must have a cover sheet? I am trying to set a cover sheet on all projects that have more than 3 sheets. In the past this practice wasn't establish in my office. The info i got is that all projects with 3 sheets or more must have a cover sheet. Correct me if am wrong.
    2005-06
    in the upper right corner
    3,508
    Default Re: Sheets Organization
    Quote Originally Posted by Pablo_22 View Post
    Hi there!
    I've never heard of such a "rule", in my opinion it depends on company standards.
    So if your company wants to set a standard where any project that has 3 or more sheets needs a cover sheet, sounds reasonable to me.
    I've done projects where there were only 3 sheets including a cover sheet.. it depends on the project, the client, the scope of work and the intent of the drawings.
    If they are "conceptual sketches for client review" then usually no cover sheet.
    My 2 cents
    Earth
    9,805
    R.K. McSwain | CAD Panacea |
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    What I see most often on a cover sheet included:
    - Client and or Project Name*
    - Project Address*
    - Set type (i.e. Design Development or Construction Documents) and issue date
    - Team information (Architect, engineers, GC, etc.)
    - Sheet index*
    - Vicinity Map*
    - Project image or rendering
    - Code information
    *Minimum I would expect to see on the first sheet ... cover or otherwise.
    Basically, you need to figure out what information needs to be conveyed. Your regulatory agency will probably specify what information needs to be provided ... it's unlikely they will specify that a "Cover Sheet" is required. If all you need is something with the project name and address, then no, a cover sheet is not necessary as that should be on the titleblock for every sheet. A small remodel may not need as in depth a code study as a new construction, which may need its own sheet (or set of sheets). If you can get the minimum information on the first plan sheet, then a dedicated cover sheet may not be necessary. What I suspect is that if you have enough information that you have at least 4 sheets, you probably need a separate cover sheet because there won't be room on your first sheet.
  1. Replies: 1
    Last Post: 2013-01-12, 02:29 AM
  2. Drawing Organization and sheets
    By jkimc65910376 in forum CAD Standards
    Last Post: 2012-10-24, 12:16 PM
  3. 2012: Export Revit Sheets to AutoCAD Sheets with External References
    By brian-kerry-smith in forum Revit - Platform
    Last Post: 2012-02-09, 08:35 PM
  4. 2012: Browser - Sheets organization
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2012-01-09, 07:15 PM
  5. Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    By KansasCAD in forum Design Review - General
    Last Post: 2007-05-18, 06:51 PM
