Thread: acadmap.log read-only message upon start up
    2014-04
    6
    Default acadmap.log read-only message upon start up
    I get the following AutoCAD Map 3D 2016 Message upon startup:
    Log file C:\ProgramData\Autodesk\Autodesk AutoCAD Map 3D 2016\R20.1\acadmap.log is read-only.
    What do I need to do?
    9,805
    Default Re: acadmap.log read-only message upon start up
    What changed before this started happening?
    Or has it done it since day 1 when you installed AutoCAD Map?
    2014-04
    6
    It has done it since day one.
    9,805
    Okay.
    Have you tried going to this file [ C:\ProgramData\Autodesk\Autodesk AutoCAD Map 3D 2016\R20.1\acadmap.log ] and making sure it is not read-only, and/or in a read-only folder?
    2014-04
    6
    Actually, I can't find this file on C:\drive.
  1. Replies: 3
    Last Post: 2008-10-06, 10:24 PM
  2. Selection set / acadmap.ini setting
    By trconnet in forum AutoCAD Map 3D - General
    Last Post: 2006-04-05, 02:45 PM
