Results 1 to 7 of 7
Thread: at a loss: Setting Field Values with VBA
    2015-12
    Santa Clarita, CA
    8
    Default at a loss: Setting Field Values with VBA
    I am using Autocad 2016 and excel 2016 I am trying to set my field values based on excel cell values.
    The problem is i dont know how to call or reference an autocad field with vba. I have searched everywhere. Disregarding the excel part can someone tell me how to reference my fields in autocad with VBA? They are already created and I just want to set their values with VBA.
    Thanks in advance
    2009-11
    5,719
    Default Re: at a loss: Setting Field Values with VBA
    Welcome to AUGI.
    Have you tried invoking the FieldCode() Method?
    Perhaps Ed, or Opie can offer something more complete... I pretty much skipped VBA, jumping from Visual LISP (also ActiveX COM) to .NET API.
    Cheers
    Computer Specs:
    2015-12
    Santa Clarita, CA
    8
    i have been playing with the fieldcode() method but cant get it to work properly it returns a run-time error '91'
    Sub popFields()
    On Error Resume Next
    '*2016
    Set acad = GetObject(, "Autocad.Application.20.1")
       If Err <> 0 Then
           Err.Clear
           Set acad = CreateObject("AutoCAD.Application.20.1")
      End If
    '*BricsCad
    'Set acad = GetObject(, "BricscadApp.AcadApplication")
    Dim textObj As AcadMText, text As String, Pt(0 To 2) As Double, height As Double
    On Error GoTo 0
    text = "%<\AcVar JOBNAME \f ""%tc1""%>%"
    Pt(0) = 2: Pt(1) = 2: Pt(2) = 0
    height = 0.5
    Set textObj = acad.ActiveDocument.ModelSpace.AddText(text, Pt, height)
    ZoomAll
    End Sub
    2015-12
    Santa Clarita, CA
    8
    Quote Originally Posted by BlackBox View Post
    Welcome to AUGI.
    Cheers
    i can add the date as shown in the example code:
    Sub Example_FieldCode()
    ' This example creates a text object in model space.
    ' It then returns the field code string for the object.
    Dim textObj As AcadText
    Dim text As String
    Dim insertionPoint(0 To 2) As Double
    Dim height As Double
    ' Define the text object
    text = "%<\AcVar Date \f ""M/d/yyyy""%>%"
    insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(text, insertionPoint, height)
    ZoomAll
    ' Return the current text string for the object
    text = textObj.FieldCode
    MsgBox "The FieldCode for the text object equals: " & text, vbInformation, "FieldCode Example"
    End Sub
    but i cant edit an already existing field.
    2009-11
    5,719
    Quote Originally Posted by janice703088 View Post
    Sure you can; just parse and/or subst the necessary components of the desired Field type.
    As example:
    If you have a Text entity that is Field mapped to a Polyline (object), and set to display the area, then want to edit the FieldCode to point to another Polyline (object), then you'd merely extract the FieldCode string, parse the prefix, ObjectId, and suffix, then concatenate them back together with the ObjectId of the target object.
    Cheers
    [Edit] - The simplest way to know the FieldCode you need, is to manually set one up the way you want it, and then examine the FieldCode string, copying from that to hard-code your source, and concatenate the bit(s) you need at runtime.
    Computer Specs:
    2015-12
    Santa Clarita, CA
    8
    I will try this thank you.
    2015-12
    Santa Clarita, CA
    8
    Hey everyone it's been a very long time since I started this thread. I just solved the issue and would like to share the answer.
    with the help of this thread: summaryinfo
    I was able to alter the code slightly to change the value of my fields:
    Dim Value As String
    Dim Num As Long
    Dim Index As Long
    Dim CustomKey As String
    Dim CustomValue As String
    Dim Sum As AcadSummaryInfo
    Set Sum = ThisDrawing.SummaryInfo
    Num = Sum.NumCustomInfo
    For Index = 0 To Num - 1
        Sum.GetCustomByIndex Index, CustomKey, CustomValue
        If CustomKey = fillArray(Index) Then
            Sum.SetCustomByIndex Index, CustomKey, "Test"
        End If
    Next Index
    Set Sum = Nothing
    I am altering this snippet to fill my fields with values from an excel sheet.
    Just thought I'd share even though the code that helped me has been on here since 2005, it was another post that pointed me in the right direction (summaryinfo) Thanks Augi community
    hopefully this saves someone some heartache and headaches.
  1. Default field values
    By junkdiver in forum AutoCAD Fields
    Last Post: 2017-02-17, 01:06 PM
  2. Editing Field values
    By cadconcepts in forum AutoLISP
    Last Post: 2016-04-01, 07:52 PM
  3. object field values scales with VP?
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2010-03-17, 03:26 PM
  4. HELP!! Setting Values (New user)
    By fets12 in forum AutoCAD General
    Last Post: 2007-12-06, 08:11 PM
Tags for this Thread
