Results 1 to 1 of 1
Thread: Object(s) outline is not displayed while using commands like Copy, Move, Rotate etc.
    13,499
    Default Object(s) outline is not displayed while using commands like Copy, Move, Rotate etc.
    Object(s) outline is not displayed while using commands like Copy, Move, Rotate etc. the most likely reason for this behaviour is the current setting of system variable DragMode.
    Below is taken directly from the AutoCAD Online Help File [F1] -
    DRAGMODE System Variable
    Type: Integer
    Saved in: Registry
    Initial value: 2
    Controls the display of objects being dragged. When Drag mode is on, AutoCAD shows the image of an object as you drag it to another position. With some computer configurations, dragging can be time-consuming. Use DRAGMODE to suppress dragging.
    0 Does not display an outline of the object as you drag it
    1 Displays the outline of the object as you drag it only if you enter drag on the command line after selecting the object to drag
    2 Auto; always displays an outline of the object as you drag it
    DRAGMODE Command
    You can draw new objects dynamically and drag them into position on the screen. You can also drag existing objects with many editing commands. With some computer configurations, dragging can be time consuming. Use DRAGMODE to suppress dragging.
    Command line: dragmode (or 'dragmode for transparent use)
    Enter new value [ON/OFF/Auto] <current>: Enter an option or press ENTER
    ON -> Permits dragging, but you must enter drag where appropriate in a drawing or editing command to initiate dragging.
    OFF -> Ignores all dragging requests, including those embedded in menu items.
    Auto -> Turns on dragging for every command that supports it. Dragging is performed whenever it is possible. Entering drag each time is not necessary.
    Links:
    Autodesk Knowledge Base:
    ID: TS21720 - Object outline is not displayed as it is moved on screen
    ID: TS41134 - No outline displayed when inserting a block
    ID: TS73219 - Unable to drag leader line while it is being drawn
    ID: TS74871 - Bounding box for multiline text is not displayed
    AUGI Forum:
    Ghost move and dimensioning
    AutoCAD copy and move commands with Eagle Point
    Ghost Guidelines?
    Objects not regenerated / selected.
    Invisible Dimensions
    Unable to see Spline as I draw it
    Can not see Objects as I Move them or Rotate them
    Dragmode not working
    See the outline of a line or rectangle as you draw it
    Missing Object Preview.
    Can't see circle while creating it
    'Construction lines' not visible...
    Dimensioning Not Displaying
    Dimension lines and arrows disappear while dragging
    Dynamic view of Dimension Text during placement?
    Show Objects while moving
    3D Solid's Silhouette disappears on moving
    Outline of Object missing when Copying
    Cannot see Objects as I move or rotate them
  1. Copy/Move/Rotate
    By joshua.harter in forum ACA General
    Last Post: 2010-01-28, 07:58 PM
  2. move,copy,rotate scale all in the same command
    By BTSIVIKIS in forum AutoCAD Tips & Tricks
    Last Post: 2005-08-29, 10:36 PM
  3. AutoCAD copy and move commands with Eagle Point
    By jasontirone in forum Software
    Last Post: 2004-11-08, 08:37 PM
