Thread: custom pallattes assistance
    2010-05
    94
    Default custom pallattes assistance
    Hello all.. I been using custom toolbars/menus to insert blocks w/ macros. I now have time to customize/setup blocks w/ a new pallete. Problem I have is when I open a dwg, make a block of something (say lav), save the dwg, drag block to the new pallete, than open a new dwg.. and it drag/inserts the block from pallate.. it wont use the macro as it does on the drop down toolbar/menu.
    A sample macro from the toolbar/drop down menu.. (^C^C(setq cl(getvar "clayer")) ortho on -layer m A-Plumbing ^C^C-insert;LAV \;;\(setvar "clayer" cl)
    This works perfectly from tool bar/drop down menu. But when I insert “lav” from the tool pallet, it just inserts the block, doesn’t act as a command and run macro like a toolbar/menu
    Any suggestions? Or a tool pallete wont run a macro when I insert a block from it. autocad 2014
    Thanks for the responses!
    2010-05
    94
    Default Re: custom pallattes assistance
    anyone happen to have any suggestions on the question?
    2009-11
    5,719
    Tool Palettes are a great resource, and often overlooked because they've been around and unimproved for so long.
    You can set a lot of Block-specific Properties with Tool Palettes - Right click the Block in Tool Palette, select Properties menu item - such as specifying a Layer, Scale, Explode, etc.
    You can also drag some native Commands to the Tool Palette, and customize those - for example: draw a Line, set some properties (or set them after, as noted above), and drag & drop that Line to the Tool Palette.
    [Edit]
    I believe this is what you're after: https://knowledge.autodesk.com/suppo...5495B-htm.html
    [/Edit]
    Another option, would be to setup a Ribbon Tab + Panel(s), and drag those free from the docked Ribbon - THOSE buttons utilize the same Macro(s) you already have, and require not additional setup (aside from the Panel[s] themselves).
    Cheers
    Computer Specs:
    2009-11
    5,719
    Quote Originally Posted by BlackBox View Post
    Just realized there was an easier way to do this....
    Right click the Tool Palettes 'gear', select Customize Commands.
    Computer Specs:
  1. 2014: Demande d'assistance
    By andre.abiven435832 in forum Revit Architecture - Families
    Last Post: 2015-11-25, 04:05 PM
  2. Handrail Assistance
    By jcoe in forum Revit Architecture - General
    Last Post: 2011-08-24, 08:38 PM
  3. Roof assistance please
    By cadmaster77 in forum Revit Architecture - General
    Last Post: 2010-06-22, 01:30 PM
