Results 1 to 7 of 7
Thread: Title Block Attributes
    2011-11
    17
    Default Title Block Attributes
    I am hoping for some help
    We work with 2-5 layouts per DWG. The attributes on these layouts remain the same for approx 90%, with the other 10% including sheet numbering and dates etc.
    Is there a way we can enter this information in once to Layout 1, and it globally change the remaining 2-5 layouts
    2008-12
    New Jersey
    472
    Default Re: Title Block Attributes
    Are you familiar with sheet set manager and fields?
    2011-11
    17
    I have a very very basic understanding of this, do you suggest this is the best method moving forward
    Cairo - no, not Illinois
    5,069
    Pretty much what Sheet Sets are good for, without having to do a deep dive into functionality. Set the SheetSet Properties for the things that do't change, and Per-sheet properties for those that do. Then just manage everything via SSM
    2004-10
    Scotland
    102
    We have a standard project folder layout, in which we have an Xref which notes the project title, job number etc.
    All our title layouts have a relative link back to the Xref.
    2008-12
    New Jersey
    472
    Another options is too create a separate drawing that contains the titleblock and the information that once is entered will not be changed for the project.
    This drawing will get XREF'd into your final drawing. Make sure you XREF this in before creating layout Tabs.
    Next step is to create just a drawing that has attributes or text of the areas in the titleblcok that will change, sheet number, name, etc. This would get inserted into PS as a block. Then all you have to do is edit that text on each layout tab.
    One suggestion is too make the text that is XREF'd and the text that is inserted a different color for each. This way you can visually see which areas of text need to be edited per sheet and/or XREF'd.
    5,719
    My previous employer was pretty high speed about letting us map our title blocks to built-in and custom Sheet Set and Sheet (SSM) properties.
    My current employer, well the CAD folks here freak out with anything like that, so I've resorted to populating the block attributes in each sheet drawing... That said, I automate the process, so I just manage the title block data in Excel, right click convert the Excel to CSV via Shell menu (the built-in export takes too many clicks!), and open the drawings I need to update:
    https://www.theswamp.org/index.php?t...7823#msg567823
  1. title block and attributes in autocad 2004
    By mescamilla in forum AutoCAD General
    Last Post: 2010-09-16, 02:25 PM
  2. Title block must have attributes in CAD format
    By BecFra in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-08-13, 12:20 PM
  3. Title block w/ Attributes
    By TDIGUY in forum AutoCAD General
    Last Post: 2008-01-03, 01:35 PM
  4. Using lisp to Edit Attributes in a Title Block
    By Red Devil in forum AutoLISP
    Last Post: 2007-08-10, 06:42 AM
  5. Title block attributes
    By a_meteni in forum AutoCAD General
    Last Post: 2004-11-10, 02:27 PM
